Hey guys,
I gotta reach out for some help in this area, i don't know much about graphics...in the near future I'm looking to hook an Inspiron 530, (which will be running XP home, 1 GB Ram, with an ATI Radeon HD Pro 2400 graphics card) to my Sylvania ssgf4276 (flat screen CRT TV). The video card has s-video, DVI, and VGA outputs and the TV has component video input.
There are adapter cables to run VGA to component but i know those cables won't convert the computer graphics to the TV RGB display.
Before I run into problems when i try to connect it all i was wondering if anyone has done this type of connection before and could walk me through the steps of what i need. I've heard one way is a transcoder (which can be pricey) or the newest drivers from ATI might allow those adapter cables to work.
Thanks for your helps guys, i hope i've provided everything that will help get an answer
Results 1 to 9 of 9
http://configure.us.dell.com/dellstore/config.aspx?oc=ddcwda1&cs=19&dgvcode=ss&c=US&l=...399&lid=627062
http://ati.amd.com/products/Radeonhd2400/specs.html
Supposed to have both HDMI and analog component capability.
Call that Dell Dude in India and ask for the right cable. Probably still in the box.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Ok great so that should be just a cable similar to this right?
http://www.lenexpo-electronics.com/products/d_2568.jpg -
ATI cards generally come with an adaptor cable that looks like a s-video-to-component adaptor, that is for component output. ATI use the s-video socket format to save space.
I would think that this is what you need:
http://sewelldirect.com/dvivideoadapter.asp
Good Luck
It seems like 2400 Pro cards vary for connectors out. Best ask the Dell Dude.
Does it look like this?
or this?
or this?
Dell may have a custom version.
These use different cables or adapters for analog component. The first doesn't seem to have analog component out. Modern ATI Radeons usually come with a DIN to YPbPr adapter or cable. DIN (TV-Out) is the round black connector.
This is the YPbPr cable that ships with the Sapphire version. The yellow adapter gets you composite.
yea that's what i've been trying to figure out. I'll probably just go through the dell guy. I started a separate post for this also but in case other people read this first any thoughts on which type of connection gives the best video quality. the tv has s-video and component connections and the video card will most likely have s-video and VGA (i'm not concerned with HDMI because its not an HDTV) so my two choices are s-video or VGA to converter to component video...whichever quality is best i'll go with
The component cable will give somewhat better quality than S-Video with your SD CRT TV. Unless it's a very expensive box, a scan converter VGA-component converter will be interior to direct component out.
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 10:38 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 12:41 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
Visiontek ATI Radeon HD2400 Pro Help
By mattman1968 in forum ComputerReplies: 2Last Post: 11th Jan 2008, 12:13 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
