After a bazillion tests I finally found an encoder and settings I'm happy with, except XviD with mencoder seems to have audio just slightly out of sync. I tried encoding with VisualHub which does pass the -async flag and it does not have the problem. It kind of sucks that you can't pass additional arguments through ffmpegX, unless I'm missing it somewhere. I have about 300 VHS tapes I'm planning on capturing and encoding, so streamlining the process is very important to me. Messing around with demuxing and fixing the offset isn't high on my list. It's bad enough ffmpegX won't work with edited QuickTime reference movies.
So... I guess what I'm getting at is is there any way to pass an async flag in ffmpegX, and if not, is there any chance custom flags will be added in the (near) future? Or is there some other easy way I can fix the audio sync issue? Thanks.
Results 1 to 1 of 1
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 21:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 15:18 -
FixVTS command line arguments pse??
By RogerTango in forum DVD RippingReplies: 2Last Post: 28th Nov 2009, 13:18 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 05:46
