I get this error message:
I tried re-extracting and using the copy from a mirror but nothing worked. v0.29 opens normally, though.
Is there anything I can do?
Thanks!
Does it create an .ini or .cfg file (or any other settings files)? If so, you might move or rename the extensions (or delete the files altogether, if you feel safe doing so) any files created by the previous version before installing and running v0.30. There might be something in the existing configuration files the newer version doesn't like.
If cameras add ten pounds, why would people want to eat them? -
Ripbot 1.13 won't open
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 9th Feb 2009, 10:45 -
Final Cut won't open
By Tom in HD in forum MacReplies: 5Last Post: 5th Jun 2008, 15:23 -
Lg external burner won't open
By coachop94 in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th May 2008, 17:41 -
Large DVDs won't open
By newtie in forum Authoring (DVD)Replies: 2Last Post: 27th Sep 2007, 19:53 -
OGMDemuxer won't stay open...
By deepdiev in forum Video ConversionReplies: 3Last Post: 13th Jul 2007, 02:07
