I'm looking to stream video games, mostly older systems with composite/S-video outputs, but also a lot of games that can output in 480p and widescreen. However, what I am NOT willing to sacrifice is the quality of my personal viewing experience. I realize I will have to generate a second set of cables somewhere in the chain, but any loss in quality or lag on my end is not acceptable. Obviously, I don't care too much what it looks like by the time it gets to my computer, because streaming is low res anyway. Just so you know, all of my composite, S-video, and component sources run out of my audio receiver as component.
In particular, I was looking at this device: http://www.ramelectronics.net/audio-video/video-converters/component-video-to-vga-rgb-.../prod9A65.html
Is anyone familiar with it? I'm assuming that it allows a component source to pass through to the TV, and then outputs VGA simultaneously.
So then, would a 480p OR 480i signal sent over that device (or similar) be recognized by a device like this one: http://www.ramelectronics.net/audio-video/audio-video-computer/pc-tv/pc-to-video-conve...odGEZ1000.html
Then I can get it to my computer using a common S-video capture device.
I've had ideas about how I'd do this, and this is the simplest one I've come up with. But my concerns regard whether a VGA box that converts to composite/S-video would understand a Y Pr Pb component source, and also whether a widescreen game would be properly letterboxed or if it would be vertically stretched.
Any ideas?
Results 1 to 1 of 1
-+- Can't Figure Source URL Stream -+-
By JaxGuy in forum Video Streaming DownloadingReplies: 14Last Post: 16th Jul 2013, 10:01 -
Trying to capture a digital slideshow, need advice or ideas.
By mpalm887 in forum Capturing and VCRReplies: 2Last Post: 29th Jan 2012, 10:37 -
Any source to MPEG2 Transport Stream with multiply audio streams
By traaance in forum Video ConversionReplies: 4Last Post: 6th Jan 2012, 07:50 -
How to stream from 4 PC/360's to a single viewing source?
By CSavory in forum Video Streaming DownloadingReplies: 2Last Post: 10th Dec 2010, 17:16 -
advice on restoring using a DVD source
By Jerry1964 in forum RestorationReplies: 10Last Post: 1st Nov 2008, 10:44
