    Jun 2008
    A friend sent me a mini dvd from her camcorder, I don't have such camcorder. Is there anything I can do. I'd love to put them on a regular dvd but if nothing else to watc it.
    Jun 2008
    portal 666
    did you try playing it in your standalone? or try putting it in your computers dvd drive and opening it with a software player like powerdvd. it should play if it was finalized in the cam. if it wasn't you may need isobuster to extract the files.
    if there are vobs on the disc you can re-author them to a new dvd.
