Will anything happen down the line?
Also, I found a hack on this site that gets rid of the region codes on my Sanyo DWM-370... but what about making it able to play PAL?
	If the hack takes, nothing else will go wrong. If the player has to go in for repairs it might be reset.
 PAL playback relies on the correct circuitry. Sometimes it is there, knobbled by the firmware. In these cases a hack might free it up. Mostly though, if it is NTSC only out of the box, it will always be NTSC only. A region hack won't change that.Read my blog here.
	What about these new DVDs that are coming out, I heard they don't play on a DVD player that's been hacked?Originally Posted by guns1inger
 Is there a hack that will?Originally Posted by guns1inger
	Crapolla, basically. A DVD disc doesn't know if you have hacked a player or not. A few years back there was a copy protection called RCE used in the US. It queried the player to ensure the player was in the same region was the disc. It didn't matter if the player was region free or not, just that it was a region 1 player. This caused a minor inconvenience for some players which could not be made region free, but whose regions could be changed instead. Users had to remember to change the regions back to region one for these discs. Any play back issues with newer discs is more likely to be related to the stupid amount of butchery the studios build into the authoring in the name of so-called copy protection.Originally Posted by Akabane Kurodo
 Not if the player doesn't have the hardware, and generally if it is NTSC only then it is NTSC only.Originally Posted by Akabane KurodoRead my blog here.
  Does changing file extension from .f4v to .flv have any negative effects?By huntaaar in forum Video ConversionReplies: 5Last Post: 2nd Sep 2010, 12:49
  Help with LG RC389H DVD player hackBy nannon in forum DVD & Blu-ray PlayersReplies: 7Last Post: 20th Jul 2010, 06:04
  DVD Player HackBy jgibson in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2010, 20:48
  dvd player hack seems to have gone wrong, any help?By johnkurtz in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th May 2009, 16:09
  can i rip DVD with pre-stated audio delay in ms (active or negative)By deejay.2001 in forum DVD RippingReplies: 1Last Post: 29th Sep 2008, 05:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
