I did some tests and it turns out that encoding from Sony Vegas using Main Concept is not actually VBR, in fact the bitrate graph looks almost the same as if it was constant bitrate. Yes, I checked the two pass box, am I missing something else?
I also encoded the same file with tmpegenc and this WAS truely VBR, the graph fluctuated between max and min as you would expect. The problem with this is I've noticed some playback problems on certain hardware.
Is there a better encoder out there?
I used the standard template, minimum 192,000 bps, maximum, 8,000,000 bps, and average I changed to 4,500,000 bps.
Checked VBR and 2 pass, it even took twice as long as a CBR encode, which seemed evidence enough. Until I noticed the quality was off and the bitrate graph was flat.
It's a shame because my CBR encodes from Vegas are perfect.
I'll check out HCEnc, thanks for the suggestion. -
If you use the Debugmode Frameserver you can frameserve directly from the Vegas timeline to your favourite encoder. Sometimes this is a bonus, although if you are doing multi-pass encoding and you have a lot of filters on the timeline it is usually more efficient to render to a lossless intermediate file, then encode to mpeg-2
Read my blog here.
How do I find out if my MPEG vidfile has variable bitrate audio?
By cwb in forum EditingReplies: 5Last Post: 22nd Nov 2010, 08:56 -
Need help to set up Variable Bitrate
By spigy in forum Video ConversionReplies: 19Last Post: 16th May 2010, 13:13 -
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 07:49 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 07:58 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 17th Oct 2007, 23:56
