I'm trying to basically cut&merge a mpg1 encoded video. When I try a quickstream fix in videoredo it cuts out a part of the video. When I use virtualdubmod, it says:
[!] MPEG: Anachronistic or discontinuous timestamp found in audio stream 0 at
byte position 68159716, from 34277884 to 35251206. This may indicate an
improper join.
It list 3 other spots as well. What TMPGEnc program can I use to cut&merge it? There's TMPGEnc mpeg editor premium and TMPGEnc video editor. I see alot of people recommend this program, I'm just confused as to which one is the better program?
Also, would that fix the seeking/freezing issue?
You can use the free tmpgenc, you find the basic editor under file->mpeg tools. But it's not as good as tmpgenc mpeg editor and videoredo.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
