hi bro,
i use Ulead Video Studio or Adobr premiere to capture video from my camcorder but the problem that the file is very big and i want to ask if there is a software can do the same job of these 2 programs but with Divx format to get the same quality with small size in 1 step ?
thanks for help .....
They are transferring as DV, so you are getting the data (and therefore quality) that was on the tape. I don't know of any program that transfers DV and encodes to Divx in a single pass. You will get the best quality by transferring as DV, then encoding. If you need to do any editing then you certainly don't want to capture as Divx.
Read my blog here.
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
What software will capture MPEG-1 ?
By Palmer Eldritch in forum Capturing and VCRReplies: 17Last Post: 4th Jan 2010, 19:12 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
capture and broadcast software?
By blader18 in forum Capturing and VCRReplies: 24Last Post: 21st May 2009, 11:02 -
Software for Capture
By ashkan_vpm2 in forum Capturing and VCRReplies: 1Last Post: 6th Feb 2009, 15:03
