My computer looks similar to this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00605601&lc=en&cc=uk&dlc=en&product=435579
I'm having a problem with step 3. I don't see any tabs on the sides of the front cover. Just the release button and the big green thing below it.
	Dumb question, but...you are looking at the inside of the case , right? There's a metal plate on the front behind the plastic cover. The tabs stick through slots on the metal plate. You have to push the tabs a bit to slide them through the slots in the frame. Nothing can stop me now, 'cause I don't care anymore.
  HP Compaq D530 P4 Socket 478 M/B - Manual ???By blinky88 in forum ComputerReplies: 0Last Post: 11th Sep 2009, 09:34
  Compaq Presario A940caBy Tom Saurus in forum ComputerReplies: 1Last Post: 29th Aug 2008, 20:27
  Can I offload SYSTEM_SAVE from an old Compaq Presario?By ahhaa in forum ComputerReplies: 2Last Post: 11th Jul 2008, 15:38
  Can an older Compaq Presario 6301RSH Desktop use PC4200 DDR2 RAM?By Denvers Dawgs in forum ComputerReplies: 3Last Post: 22nd Feb 2008, 00:27
  Compaq PC won't boot with new motherboardBy edong in forum ComputerReplies: 4Last Post: 28th Jan 2008, 10:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
