I have a number of interlaced eyetv recordings that I would like to transfer to DVD. When I use Visual Hub to create a DVD from from the interlaced source, I am getting interlace motion blurring on playaback. The DVD player (an internal Toshiba slot load which is part of my HDTV) does not seem to play the DVD in progressive mode. No problem with commercial DVDs. I know I could check "deinterlace" when I process the files but I don't think this should be necessary for a DVD, since DVDs normally contain interlaced video.
I tried ffmpegX using ffmpeg as the encoder with the same result. However, when I tried using the mpeg2enc setting in ffmpegX, the DVD played fine.
Any ideas on how to make it work with Visual Hub without deinterlaceing? Maybe there needs to be some kind of flag set? Something else?
I would consider using ffmpegx instead, but I haven't been able to figure out how to throw multiple episodes on to a DVD using ffmpegx and or encode for dual layer DVDs, etc.
Visual Hub / DVD / Where is "force anamorphic" ?
By webstar in forum MacReplies: 2Last Post: 30th Jun 2010, 05:13 -
Visual Hub converting uncompatable .avi files?
By toxicquack in forum MacReplies: 2Last Post: 29th Jan 2009, 13:19 -
Hi i'm a newbie having huge problems with Visual Hub for the Mac Help pleas
By twiglet31 in forum MacReplies: 3Last Post: 7th Aug 2008, 15:06 -
Dropped frames (or jerky video) from Toast DVDs, but not Visual Hub
By chrjohns in forum MacReplies: 3Last Post: 19th Feb 2008, 09:37
