i know is somewhere on this site for download a tool which can help you to find all subtitle formats you can play on dvd.
what i know is a disk image.
thanks
It would depend on the player. Assuming a set top player, what brand and model? The operating manual should tell you which formats will work. You could look here for methods of adding subtitles to a DVD: https://forum.videohelp.com/topic338721.html That will give you some information on compatible DVD sub formats.
If you have a disc image, then you would have to extract the DVD video if you wanted to add subs. Or just try playing back the image with VLC media player. If it has subs, VLC should see them.
You need to give more information on what you want to do and what player you have before anyone can give specific information or answers.
And welcome to our forums.
Do you mean a standard DVD-Video disk? Is so, this has nothing to do with your player, the standards are set. The limiting factor is really what your authoring program will accept.
If you mean AVI files, such as Xvid, Divx, or whatever, your manual or the player manufacturer's website would have the answer. A software tool is not going to tell you much about your DVD player, unless you have one of these DVD players that boots some sort of operating system.
Describe just how it is you "know" a disk image. Do you mean in the Biblical sense?
How put the subtitel in FFmpeg (pfffff)
By cane in forum ffmpegX general discussionReplies: 12Last Post: 17th Nov 2011, 09:54 -
DVDPlayer won´t play this video
By dexter30 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Apr 2010, 02:05 -
dvdplayer on pause
By steplock in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Jun 2009, 16:05 -
DVDPlayer B.L.E. setting?
By wiseant in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Jan 2009, 13:52 -
SubMux ~ DVDplayer problem
By Sir Liam in forum SubtitleReplies: 3Last Post: 17th Oct 2008, 08:10
