I've been trying to convert FLVs to AVIs using VirtualDub.
I finally got the lips to match.
I'm using FFDshow + FLV Splitter + VirtualDub DirectShow Input Driver 0.5 + Fraunhofer IIS Mp3.
I was getting annoying sounds in the video, so I tried to turn of FFDshow's audio decode of the Mp3 and it works nice in Windows Media Player but is loaded with static in VirtualDub now. I mean the sound and video in WMP are perfect now, but when you use FFDShow, it's zzzz sounds like a drill or something and just other sounds.
Now, how can I get rid of the static and why doesn't it do it in Windows Media Player?
EDIT: Now I'm in a weird place. If I have FFDShow decode with either mp3lib or libmad, it sounds odd in both WMP and VirtualDub. If I let Fraunhofer do it with DirectShow Input Driver, it statics. But if I use an AVISynth script with Fraunhofer it works like a charm. Yet, AViSynth would not A/V sync when I used FFDShow. Even with convertfps.
Results 1 to 1 of 1
Static image + audio track. Possible with VirtualDub?
By benquo in forum EditingReplies: 24Last Post: 19th Jul 2013, 09:07 -
Cutting a flv in Virtualdub - audio synch problems
By Faufiffon in forum Video ConversionReplies: 3Last Post: 1st Sep 2011, 14:49 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 13:53 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
Static/Dynamic Noise Reduction Virtualdub Filters
By nutty88 in forum RestorationReplies: 1Last Post: 28th Feb 2008, 09:53
