I know WinDVD 9 uses DX9c and the software video quality is just awful. The player itself is utter rubbish as well. As far as I’m aware, the last quality/stable player they made was WinDVD 6, and I don’t think it’s compatible with Vista's EVR.
Cyberlink is better than WinDVD at this point, but the player is buggy as hell (both 7 and 8 ). And I don’t even know if it uses DX10. Also, it frequently skips frames, so does WinDVD but not as much.
You can find more info about that here
http://www.hardforum.com/showthread.php?t=1133393
ATM, it seems Vista’s built-in DVD player is the best performer out of all. The video playback is extremely smooth on WMP 11. I couldn’t see any frame drops what so ever. (Note: I live in the UK and most our DVD movies are encoded in 25p (yes, 25p), so we can tell even the slightest frame drop/jump.) In fact, the smoothness can be compared to dedicated hardware MPEG-2 decoder. It also uses AVIVO more effectively. However, the sound department is rather disappointing as it lacks DTS and Dolby Prologic surround-sound decoding. And it doesn't even allow X-Fi's CMSS 3D to up-sample dual-channel to multi-channel. Finally, its Dolby Digital dynamic-range isn’t good as PowerDVDs’, which is a big issue for me.
So, is there any DVD player for Vista that actually utilizes all of Vista’s multimedia advantages (DXVA2.0 and DX10)? Also, are there any true 64bit decoders available?
Here's my system specs:
* OS: Windows Vista Ultimate 64 bit
* Case: Coolermaster Mystique RC-631Black
* Processor: Intel Core 2 Duo E8200
* CPU Fan: Cooler Master Vortex 752
* Main-board: Intel DP35DP
* System RAM: Corsair Value 2048MB DDR-667 1.8v (VS2GBKIT667D2)
* Graphics card: ASUS ATI HD3650 (I'll only be using it to take advantage of AVIVO HD)
* Display: NEC MultiSync 1970NXp (with PVA panel) and Sony 26" BRAVIA (with PVA panel)
* Sound system: Logitech X530 5.1 (for music only)
* PSU: Corsair HX520
* DVD-Burner: Pioneer DVR-215DBK (SATA)
* HDD: Samsung 500GB Spinpoint T166 HD501LJ
* Sound Card: Creative X-Fi XtremeMusic (the original 2005 version)
i just use anydvd and wmp11 with no issues. also nero 7 plays dvd's fine in vista 64-bit edition. also vlc or media player classic works. just make sure anydvd is running for any of them besides nero. enjoy
if all else fails read the manual
DVD burning software compatible with vista
By toolady in forum ComputerReplies: 6Last Post: 9th Oct 2008, 15:06 -
Are any of these programs Vista compatible?
By magicfingers in forum DVD RippingReplies: 12Last Post: 7th Aug 2008, 20:04 -
Is DVD-RB compatible with Win Vista???
By Eternal7331 in forum DVD RippingReplies: 3Last Post: 11th Oct 2007, 01:31 -
Vista compatible?
By Anonymous4374945 in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 11:55 -
Vista compatible program?
By smudger2468 in forum Video ConversionReplies: 4Last Post: 31st May 2007, 17:09
