hi all, I am very new to video capturing. I have a DV cam and I wish to capture the video and convert it to VCD format. I have yet to get myself a DVcard or firewire card to do the job.
I want to find out, what are the difference between a DV card and a firewire card in terms of video capturing? which is better? and what makes it does the job better?
Thank you.
What you need is a Firewire card. There's a lot of them out there. Most come with software that can get you started. you will need a large Hard drive as most Firewire cards capture in .avi format which creats large files. 30 minutes of capture can take up around 6 to 8 Gigs. once your files are captured, you can edit and then convert to a MPG format that will take up less space.
Firewire is a DV card. Its my understanding that Firewire was a Mac interface originally and the interface was adapted by IEEE as a standard. It is called IEEE 1394 which is the same as firewire. I got an Adaptec 1394 card and it came with some DV software (VideoWave LE) which I have since replaced. As long as the card meets the IEEE 1394 standard it should be ok. I wouldn't get the Pinnacle DV card since it seems to be a little non-standard from what I have here around the boards. I don't think you will go wrong with Adaptec although there are cheaper cards.
PIV-2.4G ASUS MB, 1G Mem, WinXP
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
DV Camera to DVD plus Firewire Card Help.
By Sikander in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2007, 15:35 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
