Hello. I am a newbie, and I need some help in choosing a player for HD files. I have a 720p TV set and a standalone DVD player that works pretty well with DVD video, but I have also a lot of video HD files on DVD-R discs, 1280x720 pixel resolution, in DviX or h264 format. My player cannot play such HD files. Can those files on DVD-R be played on a Xbox or a PS3 console, changing video format if necessary? Which of the two consoles do you suggest to use them as media players, and do they have a HDMI output?
The 360 will play x264 on DVD, in high resolution. Only certain models have the HDMI connector.
Booth systems can stream the format too, the 360 can stream or play h264 in a mp4 container as well.
Currently there are NO plans to release a blue ray player for the 360, so if you ever get into thoes You'd need another player still. However the 360 is very widely support and works well. So the decision is reall a toss up.
I haven't done so in a long time but see if perhaps you can rent one if you have a rental membership to BlockBuster or Hollywood video, they use to rent the other consoles. Rent it for a week and try it out.
Xbox 360 and PS3 format for streaming
By robotball in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2011, 14:03 -
Xbox 360 or PS3 as media server??
By Browncoat in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Dec 2008, 00:56 -
How do you keep TVERSITY connection active for the xbox 360 and PS3?
By yoda313 in forum Media Center PC / MediaCentersReplies: 7Last Post: 4th Jul 2008, 18:56 -
PS3/Xbox 360 (HD) captured to PC.
By KameronK in forum Capturing and VCRReplies: 12Last Post: 2nd Jun 2008, 22:24 -
Xbox 360/PS3 Capturing guide...
By igor_video in forum Capturing and VCRReplies: 5Last Post: 24th Jul 2007, 08:37
