  1. I tried all versions of virtual dub to make custom size work but it always says "unsupported video format" But if I use WinDVR I can use any size in my recordings.
    The only format I can use in Virtual Dub is 320x240 and 352x288
    But I want to make a SVCD not a VCD
    Now I don't want any comments about using WinDVR to record the whole thing because the quality is crappy compared to Virtual Dub.
    I have used 24bit RGB and YUY2 and different codecs like Picvideo and Huffyuv
    My capture card is:
    VA 1000 Video Station
    My comp:
    Athlon XP 1600+
    386 MB SDRam
    40 gb 7200 HD
    My System:
    Windows XP
    If u need more information about my setting just ask for them
    Thx for your time
  2. i too have had this same problem.
    Can anyone help?
