I just bought a JVC Everio MG330 (hard drive camcorder, standard definition, 30GB drive)
So far so good. Haven't had a chance to test it outdoors in good light yet (under a severe thunderstorm right now, doh!)
But I've noticed that when you hit the START/STOP button, each time it starts recording to a new file.
Is there any way to set it up in certain situations to have it CONTINUE recording to the SAME file which pushing start/stop?
example: if I'm recording say my nephew's birthday, and want to 'pause' the recording for a few seconds in order to change location / pick something up /etc/etc/etc... is there any way it can keep the current file open and continue recording to that same file when I do a STOP/START ?? I know I can just merge them in my video editor on the computer, but it would be much easier to work with one single file instead of 20+ smaller ones that are just going to be put in the same continuous video anyway.
well, everybody wants it differently
I'd first look in your owners manuel for an answer
most want the files separate (your default) which makes it easier to edit -
Yah, the manual says nothing about itOriginally Posted by zoobie
For times like say I'm filming an event, maybe I dunno, a drag contestand I don't want to record all the setup/delay time in between, just the actually racing... that's just an example, but for other things like that. It would be nice to be able to just continue on with the current file instead of having maybe 20 or 50 or whatever, smaller files. -
I think theres a few cap programs you can set...perhaps even windv
Pause/Record on DVD recorder controlled by camcorder?
By maveni in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jan 2009, 10:27 -
JVC HDD Camcorder/Cyberlink power director file import error
By lonewolf_mb in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 21:53 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 03:09 -
Pause/Stop mode won't hold with Coby DVD-755
By JohnnyBob in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Sep 2007, 08:04 -
DVD+R's skipping/stop & starting on Samsung HT-P38 ?
By dch1028 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jun 2007, 15:22
