I need an all in one video converter that supports Intel Quad Core and 64bit vista. I have searched for hours and haven't found one. Does anyone know of one?
Closed Thread
Results 1 to 27 of 27
TmpgencXpress v4 will support multiple cores. 64Bit is a harder order to fill. It'll still run just fine as a 32bit application. It also converts to many different formats.
Winmenc is free http://winmenc.blogspot.com/
You can specify the number of threads/cores
I use DVD Flick for an "all-in-one".
TM shows all 4 cores active.
I'm not sure it plays nice with Vista though?
jmohn
although not free, nero recode or tmpeg with x264 installed will use all four cores. as far as 64-bit goes, xvid makes a 64-bit version , but the peformance increase is neglibible due to the fact it just changes the memory scheme to 64 bit. also in linux x264 uses all four cores but in 32 or 64 bit mode the perfomance is the same. bottom line: video encoding only effectively uses 32 bits for now. any 64 bit one out is a 32 bit engine with a 64 bit memory 'interface'
hope this helpsif all else fails read the manual
64bit Vista (also XP, Linux and not yet Mac) are development environments currently. This goes double for heavy video processing which still struggles at 32 bit.Originally Posted by edk128
Then you add "free"? Write your own apps.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
edk128, please wait a reasonable amount of time before bumping your topic. From our rules:
Moderator redwudzPlease try not to "bump" your topic.
Replying to your own topic to get it to the top is annoying. Try to have some patience, this is a bulletin board, not IRC. It may take some time (e.g., one or two days) before someone can answer your query or question.
The answer is:
1) No current software supports "all in one", ie. every single conversion/codec/file format/container
2) No current software effectively utilizes 100% cpu utilization over all 4 cores, except those using x264 CLI as a backend on very high settings. All can utilize 1 core at least - that is, having a quad core won't prevent you from using software
3) Most software is not fully compatible with 64-bit, and most still have issues with Vista
The best solution as of now, is to use specific software for a specific goal.
Winff will do multicore if you add -threads auto to the settings:
But WinFF doesn't convert to all formats, as poisondeathray mentioned.
Originally Posted by Soopafresh
Well, I can imagine if the software was written specifically for multithreading, it may do encoding simultaneously by 'starting threads' from few points of the same file, and 'merge them back in the final process, but I'll be happy if someone would explain how is it exactly done?
Because, with linear software, even 100 cores in theory will do nothing - since they can't encode P frames before B frames are encoded, and B frames cannot be encoded before I frame is done, so unless we are talking about something completely different (like "recoding" a multititleset DVD or such where different titlesets - that means completely different streams - are simulatnously encoded). I don't see how few cores can be utilized to speed-up encoding of a single stream when linear approach is required (cannot do P before B before I).
I haven't found any significant encoding time speed-up on my quad core intel machine vs old single-core intel when using my old CCE 2.5 (obviously). The difference that is there came from just overall-faster new processor, not from its 4 cores.
We have an 'encoding farm' (kinda like 'rendering farm' in other studio - same idea where many CPUs are doing same job) but I have no clue how it works either (ain't my job anyways
well there is 1 way: if you scan the source stream for i-frames you can assign 'sections' to each core. as long as you end each section with a i-frame you wont notice a visual diffrence. sure the file might be a smigen bigger but it is possible.
theoretically the only time you wouldnt use all the cores in that fashion is short clips where there aint enough 'sections' for each core. how to write such a program is beyond me , but it should be simple see's how the encoder just sees the de-coded frame. ijust getting the decoder to report sections to the program to pass the approiate frame numbers to the encoder.
My new I5 3470 quad core with a 1080p fraps video, encoding maxed out at 55 FPS. So yummy! The 4 processors hovered around 85% or so during the process. Wicked.
If you want to see what I've done with my videos,
check out my video work on youtube, http://www.youtube.com/user/duhmez/
TEncoder
To deal with a singular file and to speed up the utilization of multi core processors one should split the singular file into parts equal to number of processors available.
On my I5 all 4 cores run at near 100% during the encoding process.
Core 2 Duo VS Core 2 Quad
By vid83 in forum ComputerReplies: 21Last Post: 1st Sep 2009, 21:41 -
Does processing video use all cores in a quad-core processor?
By sincostan45 in forum Newbie / General discussionsReplies: 14Last Post: 3rd Feb 2009, 22:42 -
Intel Core 2 Quad 9550 or Core 2 Duo 8600 for games...
By retroborg in forum ComputerReplies: 11Last Post: 11th Oct 2008, 21:23 -
How much speed gain for video encoding moving from sing core to quad?
By keesio in forum ComputerReplies: 9Last Post: 21st May 2008, 11:02 -
Intel Slashes Quad-core, Dual-core Processor Prices
By louv68 in forum Latest Video NewsReplies: 0Last Post: 22nd Apr 2008, 18:14
