  1. I'm useing TMPGEnc. to convert avi to mpg but last night i dowload a avi video with a (mm) in the name and I tryed to convert it to a mpg and an error message when opening come up im not sure wich patch i need,, can anyone help me?
    RoB
  2. i will guess a nicotine patch....
    HOW ARE WE SUPPOSE TO HELP YOU WHEN YOU DONT EVEN INCLUDE AN ERROR MESSAGE??????
    http://www.vcdhelp.com/phpBB/viewtopic.php?t=78182
    peace out,
    dumwaldo
    AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
  3. sorry i mean that it says its can not open or unsupported
  4. ok one more time....
    you go here...
    after READING that you figure you should try here....
    http://www.vcdhelp.com/phpBB/search.php
    you put in a word like perhaps 'unsupported' and that brings you to here...
    http://www.vcdhelp.com/phpBB/viewtopic.php?t=76073&highlight=unsupported
    where you find this topic discussed in very detailed manner.
    now im pretty sure that this solution consists of far to much effort on your part so i think instead what you should do is just delete the file.
    peace out,
    dumwaldo
  5. Since you didin't give what version of tmpgenc you have, I'll guess you have the newest version.
    So in short your answer is:
    Versions of tmpgenc above 12j does not support divx.
  6. Originally Posted by Kwulabear
    LOL
    i guess the reading was more that you were willing to do also, but thanks for the laugh.
    BTW that is NOT my answer
    peace out,
    dumwaldo
  7. Actually Dumwaldo, we posted at the same time. But it is funny how it worked out.
  8. sorry Kwulabear that was my bad. i should have looked at the time stamp.
    for the record ALL versions of TMPGEnc support DivX
    peace out,
    dumwaldo
