    Jun 2008
    Can this plugin be used on interlaced video or not, or does it work better with progressive frames?
    Apr 2004
    Miskatonic U
    It seems to work best on progressive material. Deinterlacing before processing doesn't work nicely with it either. Although results do vary from source to source, my experience is that with interlaced material the results are usually noticeably worse than the source.
    Read my blog here.
    Jun 2008
    Hmm, I noticed that too.
    In the interests of saving time. Do you think unfolding the fields in VDub, then applying Smart Deblocker, before folding the fields back, would increase the effectiveness?
    Apr 2004
    Miskatonic U
    Don't know how adaptive it really is. Most deblockers start form some basic assumptions regarding DCT block sizes. If you unfold then you change the block size and may well throw the deblocker off.
    Still, nothing to lose by trying.
    Read my blog here.
    Jun 2008
    That makes sense, I guess I'll try doubling the frame rate in TMpegEnc with an adaptive deinterlace, that should keep the blocks the same size, right?
  6. You could use VirtualDub's Bob Doubler filter instead of TMGPEnc. Unfortunately, I don't think VirtualDub has an un-bob filter so you'll need to weave with something else later.
