Lets say I want to make a Blu ray with lets say, 25 Episodes (25 min each) of a show, but in standard def Mpeg 2, can this be possible and what sofware (like dvd-lab pro) is capable of doing this.
thanks
Yes, it's possible. But I don't know what software that supports it. Maybe nerovision or ulead dvd workshop.
I too confirm from a friend who uses Scenarist (blu-ray standard authoring software) that it fully accepts all SD MPEG-2 streams (and audio) that are fully DvD compliant. (No re-encoding necessary.)
I don't know what to do if you want the menus from these discs to blu-ray. Not sure if this is possible.
But it is indeed very possible to pack all the episodes that will fit onto a 25/50 GB blu-ray disc and playback as a regular disc like any other BD disc in any BD unit. Even 50+ episodes/disc sounds realistic on a 50GB disc (even with DvD's bloated MPEG-2). All you have to do is rip them from the DvD as separate episodes and re-author to BD.
But I do not know of a free authoring solution... yet.
TSRemux and TSMuxeR can do it, but they only currently support one file and no menu. Unless you don't mind using an editor to join the episodes into one, and adding chapters. But I'd wait a bit.
Affordable solutions are however on their way. I'm currently looking into TMPGEnc MPEG Editor 3
http://tmpgenc.pegasys-inc.com/en/product/tme3.html
and ArcSoft TotalMedia Extreme
http://www.arcsoft.com/products/totalmediaextreme/
among others like even Ulead. However, some apps only assume that BD is only HD even though the spec allows SD, so I don't know yet if these apps will accept an SD DvD stream for BD authoring.
Current solutions like Cyberlink will do it, but it will re-encode first. Not ideal.
Others, such as NeroVision will do it, but it too will re-encode, but to HD, which will bloat the files, lose quality and plenty of time to upsize. Unacceptable to me.
Nevertheless, we are close enough to such a solution in the timeline today. The bottom line is that it is indeed possible, and will be without the second mortgage on your house to purchase Scenarist.
BTW - I personally fancy the idea of encoding them to blu-ray compliant H.264/AVC to fit 2x-3x more episodes in the same disc space...I hate VHS. I always did. -
This is an old thread, but since I came across it while looking for an answer to this same question, I thought someone else might too.
I found an answer to this question with a step-by-step guide using free tools:
http://adubvideo.net/how-to/converting-multiple-dvds-avchdbluray-multiavchd -
Yes it is an old thread, and the info posted was rather accurate, and current for, like, 2.5 years ago, just a few months after the Format War was decided.
Yes, today it's all moot. You don't need an expensive program like Scenarist, or even the consumer choices. Just use multiAVCHD.
However, keep in mind, one limitation of multiAVCHD is that the muxer under the hood, tsMuxeR, will not handle AVC streams with pulldown very well, which is in some parts of the blu-ray spec.
Again, this is a current post. This too could change, and be old info, if you grave-dig this thread again, like in 2.5 more years.I hate VHS. I always did.
Blu-ray ripping best format
By strontium_99 in forum Blu-ray RippingReplies: 16Last Post: 11th Nov 2011, 07:40 -
DV to blu-ray format
By MikeMGMVE in forum Video ConversionReplies: 1Last Post: 5th Sep 2011, 17:33 -
HD video format for Blu-ray
By dabezt in forum EditingReplies: 1Last Post: 25th Apr 2011, 05:30 -
can you make a blu ray that is is 60p?
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 12th Jan 2011, 01:38 -
Best Format Quality For Blu-Ray
By betonz in forum Newbie / General discussionsReplies: 15Last Post: 6th Jul 2010, 22:45
