Hi,
I do video editing and am currently in the process of purchasing a Samsung 2493HM Monitor and a Samsung LN22A450 HDTV. I will be using the HDTV for viewing with my video editing being done on the monitor. As you know, this will help give me the proper picture for television use on my finished video. My video card is the PNY Quadro FX3700 which has 2 DVI outputs. The monitor has a DVI and HDMI inputs and the HDTV only has HDMI. I am going to pick up my cables, but I have a question for you guys. Will these be the cables that I would need, I believe they are? Thanks for all your help, Ray
DVI to DVI for the monitor
DVI to HDMI for the HDTV
	Same setup works for me, different card but SFAIK they are all the same in this regard.
 Check your local Wal-Mart for the cables, price difference was amazing.
	 Thanks Nelson37, I'll check out Walmarts first. Thanks again, Ray Thanks Nelson37, I'll check out Walmarts first. Thanks again, Ray
	also check Monoprice.com for cables... great quality, low prices, huge selection
  Using my HDTV as a monitor for gamingBy Darco32 in forum DVB / IPTVReplies: 2Last Post: 31st Jul 2011, 05:37
  HDTV box to monitorBy kanganova in forum DVB / IPTVReplies: 6Last Post: 7th Feb 2010, 01:32
  Using an HDTV as a laptop monitor?By Wall-E in forum Newbie / General discussionsReplies: 19Last Post: 6th Oct 2009, 16:34
  HDTV Monitor ResizeBy tombowler in forum DVB / IPTVReplies: 2Last Post: 29th Apr 2009, 14:00
  DVDLab - 2 questions (design & connections)By LynnL in forum Authoring (DVD)Replies: 3Last Post: 23rd May 2007, 09:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
