    Jan 2008
    Ok so i cant record more than 2 minutes.
    http://img59.imageshack.us/img59/2594/53841176du0.jpg
    __________________________________________________ ____________________________________
    I have been following these instructions
    1) Boot in safe mode
    2) Rename SP2.cab in C:\WINDOWS\Driver Cache\i386\SP2.cab to SP2old.cab (this prevents XP from RECOPYING the following files which are replaced)
    3) Overwrite these files in C:\WINDOWS\system32\drivers
    1394bus.sys
    arp1394.sys
    nic1394.sys
    ohci1394.sys
    With older XP SP1 versions (which you can download off the net somewhere):
    4) Reboot
    Where can i download these files?
    1394bus.sys
    arp1394.sys
    nic1394.sys
    ohci1394.sys
    Please help me!
    Oct 2005
    666th portal
    you could try searching an old sp1 original install disc for winXP. you might consider installing sp3. or a quick google search displays multiple sites for downloads.
  3. The fastest way to fix your problem is to install sp3.
    Jan 2008
    I tried installing sp3 it froze up then it messed my computer up I had to re-install sp2 luckily nothing erased got a better solution?
    Jan 2008
    Ok I installed sp3 and I STILL cannot record more than 2 min. Can anyone provide be those drivers please
