hi
i bought bigger sata2 hdd and i have cloned my system (devided to C-winboot D-data) to new bigger hdd with seawizard program.
everything was ok and now i need to format older hdd and remove everything on it.
how do i do it easily in windows? how to format those 2 partitions on hdd to just one?
can i connect both system hdds (new and older) and just format old one?
or do i have to remove new cloned hdd and boot older and format it itself somehow?
thanks for help
	If you want to format the old drive with its original 2 partitions, then right click the icon and choose format.Originally Posted by deejay.2001
 If you want to combine the two partitions to create one, then you need to delete the old partitions before you format the drive. Do the following.
 Start-->Control Panel-->Performance and Maintenance-->Administrative Tools-->Computer Management-->Storage-->Disk Management (Local)-->Mouse right button click for delete/format/create partition
 yes, but make sure the computer start from is the new drive before you format the old one. Some motherboard will allow you to choose the drive to boot up by pressing certain keys stroke during boot up. Or you can can change the new hard drive to the lowest SATA connection number.can i connect both system hdds (new and older) and just format old one?
	thanks for reply but when i tried to make right click in disk management it will not give me delete,format,create partition ..it is greyed out on system disk which is devided to c and d and i want just one partition after all..
	Make sure you boot OK with only new HD in system, then disconnect and put in old HD.
 Boot XP CD, delete partitions, create partition, format.
 Never, EVER, do this with multiple HD in place. While it is not hard to do the format with more than one HD, it is way too easy to format the wrong one.
 For instance, partition 1 on drive 1 will be C, partition 1 on drive 2 will be D, partition 2 on drive 1 will be E. They alternate.
  why winxp pro SP2 is not autodetecting esata HDD rack?By deejay.2001 in forum ComputerReplies: 0Last Post: 13th Nov 2009, 10:14
  What format for VHS to HDD to TV? Playing off a HDD instead of DVD?By Rudyard in forum Video ConversionReplies: 10Last Post: 6th Aug 2009, 20:46
  cloning winXP system disk problemBy deejay.2001 in forum ComputerReplies: 1Last Post: 15th Jun 2009, 16:54
  Will my old WinXP computer be OK with a 1TB internal HDD?By FulciLives in forum ComputerReplies: 9Last Post: 21st Feb 2009, 20:56
  how to make copy of system hdd to another bigger hdd and replaceBy deejay.2001 in forum ComputerReplies: 6Last Post: 28th May 2008, 19:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
