im havin wmv file so i want to cut the video...which software is helpful.....n then i want to convert the file to avi...
Two options - first you can edit wmv with Windows Movie Maker assuming you are using windows xp or later.
Next there MAY be a version of virtualdub that accepts wmv input. I just don't know which version.
WINAVI can convert wmv to avi. As can many others. Try with the latest build of virtualdubmod or virtualdubmpeg2 first though, they are free.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Virtualdub will do both the editing and convert to AVI.n then i want to convert the file to avi...
How To Slice/Cut WMV Files?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 30th Jan 2010, 14:01 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 17:57 -
[SOLVED] How to cut WMV without re-encoding?
By JestersTear in forum EditingReplies: 10Last Post: 6th Apr 2008, 05:10 -
How can i cut out a scene from a wmv?
By denadel in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 09:25 -
How do i author dvd menu with chapters + cut commericals...with a WMV??
By chocolate_brownie in forum Authoring (DVD)Replies: 0Last Post: 2nd Jun 2007, 20:00
