In my experience you pretty much need a TBC or some sort of video stabilizer (with a TBC like function) in order to get these Hauppauge devices to capture from VHS. They (the Hauppauge devices) just do NOT like an unstable signal.Originally Posted by WinSpecToR
Some say they have no problems with VHS. Go figure *shrug*
Perhaps the type of VHS VCR has something to do with it. Having said that I've used quality pre-recorded tapes on a JVC S-VHS and a Toshiba 6-Head with V3 tech (probably one of the greatest designs ever) and the Hauppauge couldn't record without a TBC. Copy protection was NOT an issue.
- John "FulciLives" Coleman
Results 31 to 45 of 45
I just set 3 channels to PAL M, N,BHTSIK.. (soemthing like that), when I set my VCR to NTSC/AUTO without a tape playing, the image is fine, as soon as I jump the VCR to PAL the images goes all scrambled, this is with nothing playing.
Does this VHS VCR output PAL? If so what is the "NTSC/AUTO" function? That's probably for recording only IF this is a TRUE multi-system VHS VCR unit.Originally Posted by WinSpecToR
You should be able to get a signal onto the computer in the preview window ... did you get that far? If not then either the VHS VCR cannot output PAL or you have the wrong PAL settings inside WinTV 2000.
Also if you bought an NTSC unit then you can only capture PAL via the Line-In inputs ... not the tuner input. The tuner input will only work with NTSC if it is an NTSC model. However the composite/s-video input and red/white stereo audio jacks are the way to go if you need PAL and NTSC capture. Should never be using the tuner input anyway unless it is connected to a "raw" cable line (where you NEED the tuner to fuction as a tuner).
The NTSC/AUTO/PAL is a manual selection on the VCR when you put in either NTSC or PAL tape to playback.Originally Posted by FulciLives
Thats what I'm saying the preview window was able to preview the NTSC signal when I selected it ( with no tape playing ) and this is when I allocated a channel for display composite with NTSC as the setting. But when I change the VCR to PAL and switched the preview channel to an pre-set PAL channel in WINTV 2000, image is scrambled ( again with nothing playing ) I don't see how I might have set the wrong pal setting in WinTV 2000 as there were 3 PAL settings and I set 3 different channels to them and tried them.
I am trying to capture using the RCA jacks and not the tuner part of this pvr. -
As I mentioned earlier in this thread ... might have better luck with an answer over at the SHS forums.
You said you got the MCE version right? I think that version can only do NTSC but I'm not sure. You should have gotten the non-MCE version.
I'll try my luck over there, but my particular forum hasn't had any post in over a year, I hope someone will check it.
Mine says Media Center kit on the box so I guess so I have the MCE. I can always return it, but I'd prefer to avoid the hassle if I can get this one working some how. -
I emailed their tech support, waiting for an answer.
Don't want to call long distance unless I have to. -
WinSpecToR I can't find any spec on that Philips VCR456 it may not be a TRUE multi-system VHS Deck have you try using the Composite
SHS: I have been trying to use composite this whole time.
I found something interesting. I set 3 channels to Pal B,M and N in wintv2000 which didn't work as the video signal was all scrambled, but the audio was ok.
I figured I'd try a few other apps like iuvcr and virtual vcr and I was able to see the pal source fine, as they were able to let me choose the video source from pal,ntsc. Hmmm ? -
I replied earlier about not using Wintv2000, its just buggy and unstable. Thats why I use Ulead for capping. -
WinSpecToR have you test a Home DVD Player, analog TV or Cable or anything else beside the VCR how dose it look?.
From look of that image it look like more then one issues -
Well I really don't know whats wrong with Wintv, sometimes the NTSC channel looks like the above picture and the PAL vhs will work, sometimes vice versa, I guess I'll give an other program a shot, but the thing is that some programs only detect that I haev the WIN TV PVR but doesn't let me choose between the different connections.
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
what PVR win 7 (64 bit) software to use with this USB TV stick
By perfection in forum Capturing and VCRReplies: 6Last Post: 24th Nov 2011, 23:58 -
how to get over 3TB limit in win XP 32bit (connected over usb)
By deejay.2001 in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 21:59 -
Win TV USB
By Trollheart in forum Capturing and VCRReplies: 0Last Post: 18th Oct 2009, 06:25 -
Hauppauge HD PVR USB questions
By SatStorm in forum Capturing and VCRReplies: 28Last Post: 16th Jun 2009, 13:01
