O.K., I got these two .AVI files which are two parts of the same video, each with double sound track (original sound+ translation).
I want to make a DVD, but stop at the first step: joining the two .AVI WITHOUT LOSING THE SECOND AUDIO TRACK.
If anybody could help me on this, then the second step is: once I got the (big) .AVI with two audio tracks, how can I create a video folder to be burnt with either Popcorn or Toast, without losing the two audio tracks?
Sorry for being so naive...
				Results 1 to 12 of 12
	My advice would be to NOT join them before converting. This avoids lots of possible problems. When setting Toast to "Play all items continuously", the end of part one will continue with the beginning of part two.
 The current version of ffmpegX cannot do it all in one step, so you'll have to do the second audio track separately and add that later.
 Assuming this is a DivX/XviD AVI, does it have Mp3 audio or AC3 audio?
	Well, as I said, I am rather naive. I do not know how to look at the audio coding. What ffmpegx says when just opening either of the two files (and pressing the INFO button) is for video XVID, but no information on the audio coding (just bitrate, and other stuff like that). On the Audio tab. ffmpegx proposes to encode it to MP3 before I set any possible option, but I do not think that ffmpegx decision is based on the input format.
 Sorry for being so vague...
	When opening an AVI file in ffmpegX, it should also list some basic details in the Summary window (screenshot) on the left (Source format: From, Video, Audio). What does it say in the Audio field? (It will list the first audio stream it finds only, though.)
 Diego has made the excellent MediaInfo Mac GUI application, which will tell you more than enough details on just about any movie file. If you're overwhelmed by the amount of detail, you could export a text file and upload that as a file attachment with your post.
	What is written there (copy&paste) is:
 ac3, 48000 Hz, 5:1, 448 kb/s
 but it does not say anything on the second (or first) stream.
 Mediainfo looks nice, I downloaded it, but does not work on my mac (I have 10.3.9). Probably it only runs on Tiger or more...
	That's cool, because it can be used on the DVD "as-is", without converting at all, at original quality.Originally Posted by facan
 Most likely, both streams are the same format, but you should verify.
 I've read the next version will have an option for user system feedback, so the author knows when he could stop caring about Tiger and start a Leopard-only version of the software.Originally Posted by facan
 There are other tools to give you information on both audio streams:
 - VLC (Menu Window > Information > Advanced Information; click the arrows to toggle the details on the numbered streams).
 - MPEG Streamclip (Menu File > Show Stream Info)
 - QuickTime Player (Menu Window > Show Movie Properties)
 (QuickTime Player may need the A52Codec (separate download or as part of Perian) to fully recognize AC3 audio).
	Ok, thanks a lot! from VLC I got the two streams (I am copying):
 Stream 1:
 Codec A52
 Sample 48000 Hz
 Bitrate 448 kbit/sec
 Stream 2:
 Codec mpga
 sample rate 48000 Hz
 Bitrate 120 kbit/sec
 That's all, I believe. Any hints from them?
 Thanks again
	Open your source file in ffmpegX, choose a DVD preset: DVD mpeg2enc. In the Video tab, set Autosize to 'DVD 16:9'. In the Audio tab, set the Audio Codec to Passthrough.
 Make sure Letterbox is checked in the Options tab, so that your 512x272 movie will fit in a 16:9 frame by using 16 px black bar above and below.
 We'll be needing the elementary streams, so set that checkmark in the ffmpegX menu. (It's default, so just verifying is enough.)
 Uncheck Author as DVD (VIDEO_TS) in the Options tab, as Toast will do the authoring.
 Encode. This step will do the first audio only.
 Next, to convert the second audio stream to AC3:
 Open your source file in ffmpegX, choose the Movie Audio to AC3 preset. In the Audio tab, set the track number from '0' to '1'. Set Channels to Stereo. Set the bitrate somewhat lower than 448; 128 kbps seems sort of right. Encode.
 So, now you should have:
 - Movie.part1.video.m2v
 - Movie.part1.audio1.ac3
 - Movie.part1.audio2.ac3
 - Movie.part2.video.m2v
 - Movie.part2.audio1.ac3
 - Movie.part2.audio2.ac3
 Any other temporary files (.wav, .mpg) may be deleted.
 The total of the file sizes should be less than the capacity of the DVD disc.
 Next, mux the elementary streams with the Mux tool in the Tools tab. As you may see, the tool allows for two audio streams. Mux as DVD, but do not author (uncheck the Author box).
 Now you should have:
 - Movie.part1.muxed.mpg
 - Movie.part2.muxed.mpg
 Drop these two file in Toast's Video>DVD Video window. Set "Play all items continuously". Save as Disk Image. Mount the disk image. Test the DVD in Apple DVD Player, including the transition between part 1 and part 2, and switching the audio streams.
 When satisfied, burn the disk image.
	When I just tried this, Toast would only take the first audio stream and ignore the second. Bummer.Originally Posted by Case
 I found a solution to that by using iVCD for authoring the MPGs to a VIDEO_TS folder in a disk image.
	Thanks for the detailed explanations. I tried to follow your instructions, with two differences:
 1. Not able to find the "stereo" switch
 2. I excluded "decode with Quicktime", and encoded with mplayer. The reason is that sometimes Quicktime gives me problems, so I wanted to be sure.
 It lasted overall almost half a day, and at the end I got the following files:
 1. Part1.avi.ff.mpa. This is soundrack 1 only.
 2. Part1.avi.ff.mpg. This is the video, plus soundtrack 1.
 3. Part1.avi.ff.mpg.ac3. This is soundtrack 2 only.
 4. Part1.avi.ff.mpv. This is the video, with no soundtracks
 5. Part2.avi.ff.ac3. This is soundtrack 2 (second part)
 6. Part2.avi.ff.mpv. This is the video, no soundtracks (part 2)
 7. Part2.avi.ff.mpa. This is soundtrack 1 (part 2) only.
 8.Part2.avi.ff.mpg This is the video (part 2) plus soundtrack 1
 I also got two empty directories, which I think had been used for temporary files. No .wav or other strange files. I deleted the two .mpg files, so I got (except names) the same 6 files you mentioned.
 Muxing replaced the two mute videos with two videos each with two soundtracks. I was then put the two videos in the DVD window of Toast, and finally got the whole DVD.
 I repeated all steps to ensure others that they can use your procedure AND IT WORKS!
 Thanks again
  Merge .DTS track with mkv to play on LG BD570 Blu-Ray playerBy kcsongi in forum AudioReplies: 2Last Post: 5th Feb 2012, 13:23
  DVD Architect Studio 5.0 plays my files at double speed and no soundBy MCnDaHouse in forum Authoring (Blu-ray)Replies: 2Last Post: 3rd Feb 2012, 11:22
  extract/edit/merge audio trackBy skatenglide in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2012, 22:13
  Get audio track from DVD Extra instead of film sound track in VIDEO TSBy Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25
  Double problem with DVD sound and regionsBy whitehound in forum Software PlayingReplies: 32Last Post: 3rd Mar 2009, 21:00
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
