My current VHS to DVDR capture setup consists of a JVC SVHS machine (model number SR-V101US) connected to a stand-alone DataVideo TBC-1000 unit, connected to my ATI All in Wonder Card.
Recently, the SVHS machine has had some problems tracking certain VHS tapes that were recorded years ago on another machine (that was probably mis-aligned) and in the EP mode. I found I got better results by substituting in the original VCR and using that as the player for these specific tapes.
However, this second VCR is standard VHS. It does not support the Super VHS format in any way shape or form. I connected it to the TBC using the RCA connections. I did notice though that if I leave the S-Video connection plugged in (output from TBC only), I am getting a picture on the S-Video channel that is slightly better than the composite channel.
I guess my question is - is this proper? Should I disconnect all the S-Video connections from TBC to capture card when using a player that does NOT support SVHS?
Thanks.
SVHS is a tape format. S-Video is a type of video connector. They are unrelated.Originally Posted by justin81
Feel free to use what looks best to your eyes, composite or S-Video, with either
tape machine. -
Both VHS and SVHS are recorded with separate luminance and chrominance components (color under system). Both benefit from the added quality of the S-Video Y/C connection but standard VHS recorders lacked the S-Video connector. If you play standard VHS tapes on an SVHS player over S-Video, you will see an improvement.
In your case you are using a composite connection to the TBC. That is the weak link in your chain. The damage is done there. Downstream Y/C separation will be lower quality whenever composite is used upstream.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Capturing SVHS using a standard VHS VCR - Is it possible?
By DJ Kris in forum Capturing and VCRReplies: 15Last Post: 4th Jul 2020, 13:00 -
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 13:50 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
Weird problem outputting a JVS S-VHS player to Sony KDL46V5100 flat-screen
By David K in forum RestorationReplies: 2Last Post: 20th Jun 2009, 23:02
