All my music is in one folder, in shared documents, my music, it is also the monitoring folder on WMP however, only 915 songs out of 4000 songs can be added to WMP for some reason, I tried manually adding and everying. I have been looking for answers using google, I've deleted the "CurrentDatabase_59R.wmdb" and 2CurrentDatabase_360.wmdb" files, still nothing. I then found this link, on how to fix the problem on command prompt but once I enter the code, I get parameter not found, what am I doing wrong?
attrib –s “c:\documents and settings\all users\documents\my music\music\*.*” /s /d
I just entered:
attrib -s *.* /d /s
This will turn off the System attribute on all files and directories. A number of files that are hidden will generate errors, but that can be ignored. -
the only problem is that all my music now needs to say in 'My Music' folder and I keep having to do this every time I have new music, what is the problem, I don't understand, this is only a temporary solution
Lagarith won't play in MPC or WMP
By mst in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2012, 19:29 -
How to delete music files from WMP Playing List
By usta in forum Software PlayingReplies: 0Last Post: 25th Jun 2009, 10:28 -
WMP Music Database
By Nitro89 in forum ComputerReplies: 4Last Post: 25th Jun 2008, 19:10 -
Playing wmp music samples at Amazon
By NiteLite in forum Newbie / General discussionsReplies: 19Last Post: 12th Aug 2007, 15:02 -
Files that won't play properly in WMP or after conversion
By Trapper Dave in forum Video ConversionReplies: 1Last Post: 3rd Jun 2007, 14:26
