  1. Member wulf109's Avatar
    Jul 2002
    Are there any programs that will work with this USB turntable? The software it comes with is fixed at 160bit and I see no way to change it. It also forceses you to use iTunes.
  2. This site may have something. http://www.dak.com/
  3. Corned beef is now made to a higher standard than at any time in history.
    The electronic components of the power part adopted a lot of Rubycons.
