I have all my movies ripped to my HDD using DVDFab. I was originally looking to create AVI (divx/xvid), but from reading through all the threads here it would appear I should go the route of h.264 (MKV/MPEG-4 AVC). I have a PS3/XBox360/SageTV that I want to stream my movies to (tv sizes from 42' to 60'). I am more concerned about the high quality of the file I create then the size. I have used trial versions of ImToo, CloneDVD Mobile, Avs4you,Xvid4PSP,Movavi,Cucusoft, etc...) with mixed results. I am torn between trying to learn some of the free software out there (meGUI, AutoGK, etc...) or paying for a do it yourself software (i.e. Nero Recode, ImToo, etc...). Unfortunately between work and the family I don't have the time I used to (i have read several guides for AutoGK, meGUI, x264 Encoder Settings, etc... and with all the different options and codes it can get a little intimidating since I don't have a lot of time to dedicate to), so I would prefer software that was straight forward and DIY. I have used enough trial versions of different software and have not been impressed, so it is hard for me to pull the trigger and spend money. Like I said, I would like to convert my DVDrips to high quality h.264 (MKV/MPEG-4 AVC) without having to read tons of guides. Maybe this is still a developing technology and I just have to suck it up and learn some of these free programs... Any thoughts or feedback would be greatly appreciated
You have already done the ripping and you want a quick and simple way to convert to high quality avi, right?
I have been converting dvd files to avi with imtoo dvd to mp4 converter and clone dvd mobile. For simplified setting (divx avi) tell both that the target device is archos av700. Keep the size at 720x480 and experiment with the bitrate (or quality) setting.
Both allow you to convert only the main movie. The clone dvd mobile outputs a smaller file most the time and is quicker. DVD mobile may be less expensive, but you have to decide which one makes a higher quality video.
Best way to rip and encode TV episodes to DVD?
By MackSwagga in forum DVD RippingReplies: 8Last Post: 28th Mar 2011, 20:16 -
How to re-encode an upscaled 720p rip
By mysteryman26 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2011, 03:52 -
Any software that can rip AND upscale DVDs?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2010, 14:05 -
Audio synch problem using MTR and ffmpegx to rip DVDs and encode for ipod
By becky_s in forum ffmpegX general discussionReplies: 1Last Post: 2nd Nov 2007, 01:15 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 09:02
