Is there any way to remove all the information such as timing, chapters, etc...
but leave the raw footage from a dvd?
I'm having problems with one section of this dvd I authored. I put together the
dvd from different clips in a certain order. I was hoping it would just combine everything
into one long video with the chapters in tact. Something went wrong with 1 clip, so that
section plays strange. I can't fast forward or skip chapter and it has problems in some players.
Now I just want to take this authored dvd and convert it into one long video file that
I can divide up into chapters. Any way to do this? I'm having a lot of problems with dvdlabpro.
Just demux it (PGCDemux) and start over again.
You can add chapters in 29.97fps frame number format (or 25fps frame numbers if for PAL) for Muxman, if you like, remux it in Muxman, and then add the "new and improved" version back into the original DVD using the "Replace" button in VobBlanker. That way you keep the menus and anything else that might be in that DVD -
If you authored this with DVDLab Pro, than I would do it over.
What could be a problem is that one of the clips was not exactly DVD compliant file.
You will not fix it by combining the file you have to do it before import to DVD Lab.
All clips in one VTS have to be exactly the same specs (Video and Audio).
Each clip will have its own chapter points and you should use "Rebuild frame index" before setting chapters.
3 instances of footage on 1 DVD need to isolate all 3 as VOBs
By paul555 in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2009, 02:30 -
Giving raw Fraps footage some extra compression
By Virnec in forum Video ConversionReplies: 12Last Post: 30th Oct 2008, 22:26 -
DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)
By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 13:39 -
burning 1 hour of raw footage onto DVD
By sfischer in forum Authoring (DVD)Replies: 2Last Post: 8th Feb 2008, 20:28 -
Raw HC7 footage for download?
By tranbuimd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 21st Jul 2007, 13:16
