I am capturing in Win2k with WinTV Theater and I am having the EXACT problem. Sound is fine and loud in TV program and during capture but file playback its all low and muted. I have a sblive value. ANY IDEAS??
There should be a program called AudioSel.exe on your WinTV installation CD. (It might also be available on Hauppuage's web site.) You can use this to select the appropriate audio source immediately before capture. It might even work during capture (if the audio switches after a few seconds). Using AudioSel.exe may fix your problem.
-Cart
http://www.geocities.com/lukesvideo/index.html -
I don't know if this will help you, but it's worth a shot..
I just got my WinTV dbx card today, and started fooling around with it. I had the EXACT same problem (Audio was fine during capturing, but I could barely hear it when I played the capture back).
I double-clicked the 'speaker' ICON in my tray (volume control), and clicked on 'OPTIONS', and then 'PROPERTIES'. Once in there, I changed the 'adjust volume for' radio button to 'RECORDING' (it was on 'PLAYBACK'). After doing that, my volume control window changed to 'RECORDING CONTROL', where I discoverd the 'SELECT' check box under MIC was checked. I checked the 'SELECT' box under 'LINE IN' instead, and captured a new clip. Sound was MUCH better..
Hope this helps anyone having similar problems.
(As a side benefit - I can't understand why, but this also seemed to greatly reduce the number of dropped frames I was getting - tackling that project is next).
Need Help Capturing with VirtualDub and Hauppauge WinTV via Svideo
By ibAdam in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2011, 21:01 -
Capturing from Hauppage USBLive2 WinTV device !!!
By imperialguy in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2011, 16:13 -
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 15:22 -
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2009, 00:10 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 00:21
