(I don't have a Pioneer DVD Player)
Have you tried to run FixVTS on the created DVD files
in VIDEO_TS before you burn them ?
Sometimes that can help
Start up FixVTS
Drag and Drop a VOB file on top of the FixVTS window
Click on the "Full DVD" button
When it say "DVD Done" you can close down FixVTS
Now see if the DVD files work, play them in a media player.
If it's ok, then you can delete any backup directories in the VIDEO_TS directory.
Now burn the VIDEO_TS directory to DVD with ImgBurn
(Write files/folders to disc)
FixVTS - https://www.videohelp.com/tools/FixVTS
ImgBurn - https://www.videohelp.com/tools/ImgBurnHubba hubba zoot zoot.......... :) -
I have another tip.
Try to use the program PgcEdit (before you run FixVTS)
it is very good to find errors in a newly created DVD.
PgcEdit - https://www.videohelp.com/tools/PgcEdit
Almost all programs I have used for converting different video files
in to a Video DVD format has errors in it's code.
And by load the newly created DVD into PgcEdit and then let PgcEdit
find and correct the errors.
And then let FixVTS do it stuff on the corrected DVD, then you have
a DVD that is more likely to work in almost all kind of DVD players.
(the same goes for ripped DVDs)Hubba hubba zoot zoot.......... :)
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
svcd2dvd wont clear dvd_output folder
By geb in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 14th Dec 2008, 16:00 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
dvd burnt using avid wont play on some players
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 10:01 -
SVCD2DVD 2.5.2725 Wont create dvd
By Stuart-ASI in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 21st Jun 2007, 19:54
