anyone using it successfully? i tried it out and get it to run fine. i connect two quad 2.4 and a dual 2.4 for a total of 10 cpus over a gb enet lan that transfers at about 65MB/s which is the speed the drives can sustain. a test run shows all 10 cores using about 50% cpu and the render takes around 3 minutes. running the same render on one quad 2.4 takes 1 minute. ??? at what point is vegas distributed rendering useful? anyone know?
Hmm. Rich man's problem.Originally Posted by aedipuss
I've tried it with P4 and core2duo. I find there is idle time while you breakout and assign tasks. A fast LAN is needed (gigabit that is acrtually working). I think the bottleneck is the network but have not investigated too closely.
I've had best results with effects/composite rendering. Less so with encoding.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
just a working man's problem. they all render for my small (one man) video business and they are all i've got., and i built them all in house. i was hoping to use them all from my workstation but it's seems it's faster to roll my chair around to the other computers and use them individually on separate projects.
That's what I do for encoding. The Vegas render farm helps with complex effects or composite layer rendering. You can assign the render to another machine and keep working. When the render is done, you can preview.Originally Posted by aedipussRecommends: Kiva.org - Loans that change lives.
Video Processing Signal Chain Question
By generallee in forum Capturing and VCRReplies: 2Last Post: 23rd May 2011, 03:33 -
Distributed video encoding
By exiled350 in forum Video ConversionReplies: 8Last Post: 10th Nov 2010, 00:28 -
Question about iMovie and single field processing
By jea46f in forum Capturing and VCRReplies: 0Last Post: 11th Jul 2010, 13:26 -
DivX network distributed video encoding
By logicom in forum Video ConversionReplies: 1Last Post: 24th Nov 2008, 10:42 -
Vista Processing Question
By RKelly in forum ComputerReplies: 5Last Post: 16th Dec 2007, 12:59
