I have a Philips DVP 5982 player that I connected to my TV's HDMI input.
I then went into the player's settings, Digital Audio, and set HDMI Audio to On (these are not the exact titles, but if you've set this up, you'll hopefully understand what I'm talking about).
Everything's fine and dandy, except, every other time I turn off and then turn on the player, that setting gets reset to Off, and I need to manually change it back.
Has anyone run into this before?
This is a known problem with this player.
You can set your tv to DVI instead of HDMI and run audio cables to the tv or you can try to make sure that you turn of the player before you turn off the tv.
I chose to go with the first one.
Philips 5982 & 624x352 AVI Playback Problem
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2010, 16:20 -
philips 5982 divx playback problem
By wkk in forum DVD & Blu-ray PlayersReplies: 35Last Post: 26th Mar 2009, 13:56 -
Phillips 5982 no 5.1 over HDMI :(
By Fearnot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Mar 2008, 23:49 -
Phillips 5982 - Which receiver inputs for sound when using HDMI ?
By Fearnot in forum DVD & Blu-ray PlayersReplies: 19Last Post: 13th Dec 2007, 17:45 -
Philips 5982 Reverse Search Problem
By rvman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Nov 2007, 02:14
