Hello Evrebody:
Does anyone know if there is a plugin to work .rmv files in Ulead VideoStudio 11?
Any help would be greatly appreciated.
Thanks.
Not that I'm aware of. You can open most RM(VB) video in VirtualDub Mod by using a simple AVIsynth script, then edit it, though output would be in a AVI type format: https://forum.videohelp.com/topic289872.html That works fine for me with most RM type video.
RMVB is a real PITA to work with because of the variable bitrates used and the proprietary format. If I needed to edit it, I would convert it to a more 'friendly' format first. DV-AVI would be my first choice if the source video is high quality.
Other members may have some better ideas.
And welcome to our forums.
ULead VideoStudio 9 Burning Error
By pcork23 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2011, 09:39 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 08:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 14:43 -
Ulead videostudio clipping guide
By Bjs in forum User guidesReplies: 4Last Post: 26th Nov 2008, 14:23 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 17:21
