Tools used:
DVD slideshow GUI
Ffdshow
Windows Movie Maker or DubIt
Super
Tutorial:
DVD slideshow GUI:
Make your slideshow in DVD slideshow GUI and export as .avs and save the project.
Ffdshow:
In Ffdshow enable the avisynth video decoder.
Then run start - all programs - ffdshow - makeavis
Load your .avs file and save as .avi.
(The trick is that the avi file calls the ffdshow codec which then calls the avisynth script (normally WMM won't like an avisynth script).)
Windows Movie Maker / DubIt:
The new (small) file with an avi extension can be imported into WMM or DubIt.
Add your music/speak in WMM or DubIt.
Saving from WMM:
Save film file - On the computer - Other options: DV-AVI(PAL or NTSC)
The audio must be split from the video in ex. Super
Super:
Load the avi and export as wav(no video) with 48 Hz.
Saving from DubIt(alt.):
Split - Save audio as... wav
DVD slideshow GUI:
Open your old project.
Add music - load your wav.
Now the audio(with music and/or speak) will be in sync with your slideshow and you can export it as you like.
Have fun,
Tin2tin
Results 1 to 1 of 1
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 09:31 -
Realtime Slideshow sync to music beat
By P_Cherry in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2007, 02:59 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 20:11
