    Jun 2008
    Canada
    Hi,
    Does somebody know how to set that DAYTEK player (P871)
    so it can play DVDs from all regtions. (code 0).
    I tried to set it with 1379...
    but I cannot change the code number to "0".
    Many thanks,
    Jean*
    JEAN* :newbie:
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It's possible that you are performing the hack incorrectly or your model is likely newer (newer firmware) and it has been modified or locked to prevent the code from working.
    Google is your Friend
    Jun 2008
    Canada
    Thanks for the answer.
    I can assure you I performed the hack correctly...
    It's just that I couln't change the number with the remote.
    Since the arrow button didn't work, I tried some other buttons.
    Without any succes!
    À+++++
    JEAN* :newbie:
