    Jun 2008
    Any tips on how to convert .asf format to a Mac compatible format that can be viewed and edited in imovie??
    HUGE THANKS for a speedy reply!!! I've got a video I need to piece together for some students by tomorrow night for
    their summer camp.
    THANKS!!!!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Your major hurdle will be finding apps for a Mac to perform the conversions, plus you will need to know which formats are supported by inmovie. Have you checked the HOW TO: Convert section? Just enter asf > X (X = whichever format is supported by inmovie).
    Google is your Friend
