Ok Ive tried everything... technically this is the problem... when I capture something to avi using Huff codec and then try to encode with CCE, it gives me a buffer underflow error....
Now I tried to use the PICVideo MJpeg codec.... the avi looks great... but when i try to encode... it works for bout a minute then give me this error message:
cce encoding failed: ICDecompressEx() failed (-367)
I really need to get this fixed... any help would be appreaciated
TY
are you on window xp pro ?? and try clicking on file new every time you used the program
Are you opening the avi with cce or frameserving?
Frameserving solved all of my problems with cce. -
Hi!
Just thought I'd add my experience .........
I'm using CCE2.62 and I get a buffer overflow (I assume 'ovf' means 'overflow'?) when I try encoding a long 'fake' AVI.
(ie. 'fake' as in VFAPI-converted)
It happens more often when I try to split the output files into two or more by setting the frames to encode.
I'm using Win98SE on an Athlon 1700XP by the way.
Anybody had this before??
When I frameserve from VDub (via VFAPI-conv1.03b), it works without a problem ....... but it is significantly slower - 1.5fps for straight AVI and 0.8fps for a frameserved version!! grrrrrr
Any ideas would be much appreciated .....
Cheers,
Sue xxx
Hi Truman (again!)
It was an MPEG2 encode with pretty modest bitrates of ave.1150 min.450 max.2200 ready for xSVCD.
However, when I got the errors I was encoding a DVD rip at full resolution (720x576).
I've still to do a few more tests, but, as far as I can tell, it only seems to happen on long encodes (120mins) that I've split by setting the 'in-out' frames and doing two 4pass VBR encodes.
That's all the info I have at the moment ...... any ideas?
Sometimes I get a different 'error' where CCE2.62 stops well before the end of the movie.
The readout that shows elapsed time, estimated time, encode rate etc.
suddenly goes weird and the encode rate starts to rise from around 1.2fps upto 35fps!!
The estimated time starts to rapidly increase as well.
This goes on for about 30seconds before CCE 'bails-out' and just comes to a grinding halt!
No error message, no nothing ....... I mean it looks as though it's finished encoding OK!!
Anyhow, any input would be appreciated ..... I'll get back to you with any new developments.
Thanks mate,
Sue xxx
Originally Posted by kcjohnclark
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 10:45 -
VBR in CCE SP2 creates playback time error leading to no audio
By Albedo in forum Video ConversionReplies: 22Last Post: 11th Jun 2008, 15:23 -
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 04:24 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
