Hi.
I need to patch the resolution in .vob files (from 720x576 to 704x576). DVDPatcher normally works fine, but for some reason not all 1 GB .vob files can be patched (don't know why).
Is there any alterative tool which is able to patch .vob files?
Thanks,
Any error message in dvdpatcher when it wont work? Or what happens?
Do you mean you load each file separately (and some can't be patched) or just open the first one expecting DVDPatcher would find the rest? Are you using the option 'patch whole file'?Originally Posted by geohei
DVDRemake (in case you have the complete DVD folder).Is there any alterative tool which is able to patch .vob files? -
When starting to patch, DVDPatcher says that someting like the .vob wouldn't be a valid video file. I don't have such a .vob available at this time. I will post the details as soon as one hits me again.Originally Posted by Baldrick
@Alex_ander
I have to patch each .vob file (I don't expect DVDPatcher to find the other after having selected the first one). Yes, I use the "patch entire file" option. DVDRemake ... does it touch more that just the resolution? If yes, I'll give it try. If it reconstructs the entire VIDEO_TS files, it's the wrong tool for this problem.
Thanks,
Change VOB Resolution
By Simmons in forum Video ConversionReplies: 4Last Post: 30th Aug 2011, 07:37 -
How can I change (patch) the initial resolution of *.swf/*.flv videos?
By pxstein in forum Video ConversionReplies: 1Last Post: 24th Jan 2011, 16:47 -
Trying to better the quality of VOB file to a better resolution etc.
By LegendaryGamer in forum RestorationReplies: 3Last Post: 22nd Mar 2010, 16:09 -
Editing Picture Resolution on MPG2 and VOB files
By vivivivi in forum Authoring (DVD)Replies: 1Last Post: 9th Apr 2008, 18:16 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
