hi,i wan to convert 1.4 gb avi file to 700 mb file so hw shud i do it??? need help plzzz....
Results 1 to 16 of 16
well actually i 2oo didnt undrstnd hw its was rippin well i uploaded a file size of 2.1gb avi file then i selected output size 1cd 700 mb n the compression strtd in virtualdubmod 1st i got audio then video aftr dat another i thought it was mixin the two ...n then wen i opened the file thers no audio n video was struckin frward n backward......n im tryin in AVIRecomp.........n let u guys knw if its workin 2oo r nt
Baldrick is ther any step by step guide.......well actually i want 2 compress 2cd dvdrip[1.4 gb] avi files into 1cdrip avi files[700 mb]........thats wat im tryin 2 do
So then, what you want to do is take a possibly good rip and make it a bad rip. Over compressed kind of like the way you type.
You did type something that MIGHT have meant that you stopped the process after one hour. That would do it. Real good. Might not even play in VLC. And since it was stopped early it wouldn't have the sound muxed in.
Please do drop the pseudo leet speak. Its not elite. Its just hard to read. The idea here is to help each other, not to show that you are a member of a tribe of 13 year olds that think they know all about computers yet have virus infected PCs. -
stranzer: You been doin a lot of textin?
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
@ klasfo,r n0 tink is doeen on poopose.....
" Who needs Google, my wife knows everything" -
Seems likely. Learns slow too.Originally Posted by t0nee1
I keep this in mind. The first person I knew in high school to graduate from college was retarded. Not figuratively but very much literally. If he could learn anyone that has learned to stop drooling can.
Of course they have to want to.
stranzer
guns1inger, not surprisingly, has it right you are re-encoding not ripping. It takes time. You didn't give your first attempt enough time to finish at least based on what little you said. Hard to tell though.
By the way, even Hebrew has vowels now. Learn to love the vowels. You use them when you talk I bet. Try typing them. I bet they are on your keyboard so no cording is needed.
Anyway a movie on one cd tends to have poor quality. Blocking becomes something you can't avoid if there is much movement. The resolution is usually knocked down considerably from the original. Now if you are converting for a Ipod or even a PSP then you can get acceptable quality for the player. But for a PC or even a standard television it will be quite poor.
Unless of course you like blocks. Then go for it. The Lego version of Star Wars is a good game.
Oh for maximum compression you could try this version of Star Wars.
http://www.asciimation.co.nz/
Of course he has been re-encoding for quite a while now. He is up to Luke meeting Leia in her cell. A mere eleven years in the process but the bit rate is phenomenally low. You must try this method out for your next attempt to re-encode.
Of course, to do this you MUST learn to use vowels.
How to rip 7GB DVD into 700MB MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 15Last Post: 9th May 2011, 01:48 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 21:55 -
Blueray to a 700mb .avi file
By withmenilu in forum Blu-ray RippingReplies: 1Last Post: 24th Jun 2009, 06:07 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 20:11 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 22:22
