Hi Folks,
I am still a newbie when it comes to capturing videos and authoring DVDs, so I hope someone can help with this.
I have a Sony HandyCam HC30 camcorder, I also have the firewire cable to transfer the video to my computer. Here is where the question comes in.
I have been using DVIO to capture the video to my computer and Using VDub to make small edits (cutting out un-needed frames etc). Then I use ConvertX to DVD 3 to burn the DVDs. I just caputed a 12min video and the size was 12GB
When editing in VDUB I use Direct stream copy to just cut some frames out (like someone filming the floor etc). After I make the cuts I import into ConvertX to burn.
Should I be compressing the video before loading it into ConvertX to minimize file size. I would like to keep a good quality but I also do not want 20-25 mins of video to take up a whole DVD.
Should I be capturing in VDUB instead?
capped DV is 13GB per hour
it sounds like vdub is saving your video uncompressed...try setting it's compression to DV
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Cannot capture - DV Camcorder to PC
By kev35 in forum Capturing and VCRReplies: 9Last Post: 8th Sep 2008, 09:43 -
Can you capture from a MiniDVD camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Sep 2008, 21:52 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Necessary to capture from a dvd camcorder?
By bobogs in forum Capturing and VCRReplies: 4Last Post: 17th Jul 2007, 03:13
