Anybody know where I can find a Custom Matrix file or how to make one? Not sure what it is, but I need one for testing purposes.
HCEnc comes with a ton of custom matrices included, most of them lousy for DVD, but developed for use in XviD AVIs. Also, how they're to be used determines the format in which you make or get them. For example, for use with CCE you type them in from a format like this:
XviD takes them in a weird .txt format, and HCEnc in .cqm format.Code:08 08 08 09 11 13 14 17 08 08 09 11 13 13 14 17 08 08 11 12 13 14 17 94 09 11 13 13 14 17 17 94 11 11 13 13 14 17 94 94 13 13 14 16 17 20 94 94 13 13 14 17 94 94 94 94 13 14 17 94 94 94 94 94 12 12 13 14 15 16 22 26 12 13 14 15 16 22 26 32 13 14 15 16 22 26 32 41 14 15 16 22 26 32 41 53 15 16 22 26 32 41 53 94 16 22 26 32 41 53 70 94 22 26 32 41 53 70 94 94 26 32 41 53 94 94 94 94
If you wish to create your own, use LiGH's Matrix Editor. That same first post also links to a custom matrix collection:
http://forum.doom9.org/showthread.php?t=73666&highlight=matrix -
Thanks as always manono. I need it to test the Custom Matrix parameter for an application I am writing
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
player with file/custom option and BD-RE/50gbs
By asiafan in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Oct 2011, 16:29 -
Custom file size using Avidemux not saving properly.
By Xaiphong in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2010, 00:27 -
Custom Video Converstion Help 720p to custom 720p
By powerplyer in forum Video ConversionReplies: 5Last Post: 4th Jun 2009, 14:14 -
How to decide what custom matrix should be used when encoding with HC .021
By jakefree in forum Video ConversionReplies: 10Last Post: 14th Jun 2007, 04:24
