I guess the topic title is a little vague, but it's all i could think of.
Basically i have a capture card (Pinnacle MovieBoard 510-PCI) connected to my VCR (LG LV880), and i am in the UK (PAL Region).
I have been given a VHS tape to transfer to PC/DVD which was recorded from TV in Brazil. I thought it would be fine because upon quick glance Brazil is also a PAL region.
However after trying to capture it with several settings, i was not suceeding. It was either black and white or green/flickery. So i did some internet research, and found that Brazil actually uses the PAL-M system, unlike the ones used in UK and other European countries.
It is apparantly more like NTSC than PAL. PAL-M is a lower resolution (525 lines instead of 625) and a higher frame count (30 frames per second at 60Hz versus 25 frames per second at 50Hz). PAL-M grew out of NTSC as an attempt to correct the inherent color problems of NTSC. PAL-M is essentially PAL at NTSC line and frame rates. The only major difference is how the color is processed. ie: the sub-carrier frequency.
So, does anyone have any experience of this? Is there any settings i can tweak to be able to capture this properly, or is it not possible for me? My VCR plays it ok into my TV, so i'm thinking it's my capture card that is not compatible.
But if not, who can capture it? Because the person i got the tape from was in the USA (NTSC) and he said on his system the picture was also black and white and bad sound.
So this is really confusing me. What do i need to capture PAL-M tapes?
Thanks for reading and any advice you can offer,
Simon
Results 1 to 14 of 14
Originally Posted by Killer3737
PAL-M was created to eliminate the possibility of illegal import of standard NTSC or PAL TV sets into Brazil thus protecting the local manufacturers from competition. RCA corp was a major contractor on the studio/transmitter side and helped develop the format. TV sets were manufactured inside Brazil under contract. PAL-M TV set import was taxed to the level of impossibility.
Technically, PAL-M is identical to NTSC in all respects (i.e. 525 line, 60 fields/sec, ~3.58MHz subcarrier, UV bandwidth) other than color (colour) encoding/decoding was PAL, not NTSC. RF TV channels were spaced 6MHz. identical to USA/Canada/Mexico so that NTSC broadcast equipment could be simply modified to PAL-M.
From the consumer capture products viewpoint, PAL-M has been tied to NTSC hardware/firmware/software rather than PAL to keep illegal Euro transhipment under control. For example, ATI All-In-Wonder products are divided into NTSC/PAL-M and PAL (other). I'm ignoring PAL-N (Argentina) for this discussion as off-topic*.
So from your standpoint, using the ATI AIW example, you need an Americas spec product that supports PAL-M. Other strategies require PAL-M decoding to YUV, YPbPr or YCbCr components. After decoding, component PAL-M is identical to component NTSC.
There probably are other PAL-M capture options with equipment available in the UK. Brazil dub experts will know.
* FYI PAL-N is 625/50 inside a 6MHz channel with subcarrier at 3.58MHz instead of 4.43MHz.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
my capture card has settings for pal-m, it's just a cheap kworld. it might work, but i've never run across a tape i need it for.
I had the self-same problem a few years back.
I explored the various hardware options - standards conversion units, multi-standard VCR - but with only one tape to do (and just a few NTSC ones lying around - these were just not financially viable.
Eventually, I found a very reasonable conversion service here within the UK. And a very quick service too. I have NO commercial interest in this business - I was just a customer(used it twice in total) and would only pass on the details of this person on this basis (the web site is still active but I have no idea whether he still does this work)
If you want the details, pls PM me. (Do not want to fall foul of the mods)
Thanks for the replys, appreciate it.
Originally Posted by ßsimian
So assuming my capture card is the problem and it infact needs to be captured by someone with an NTSC one, what region VCR would they need? PAL or NTSC? Because the person i got it from was in the US like i say, and when he played the tape back on his VCR, it was again Black & White?
Confused, am i. -
With one tape, I think getting someone else to do it is the best advice.
Otherwise you either need a VCR and capture card that handle PAL-M, or a VCR that converts PAL-M to NTSC and a capture card that handles NTSC. I have the latter - the method works just fine.
UK VCRs don't play NTSC or PAL-M natively - many play back NTSC as PAL-60 or NTSC 4.43 (for viewing on UK TVs - many capture cards don't cope with either), but I don't think any "normal" UK VCR will know what to do with PAL-M!
The reason your capture card can't capture the PAL-M tape a PAL-M is either because your drive doesn't match the capture card's real abilities, or (more likely) your VCR is not (and cannot) output(ing) PAL-M.
Cheers,
David. -
Thanks. It's actually two tapes, i forgot to mention that, but still not a lot, no. So sending these tapes back over to someone in the USA with a VCR that can convert PAL-M to NTSC would be the best option then. Darn. That was $15 wasted getting them sent here.
How will someone in the US know if their VCR is capable of that though? The person who i got the tapes froms obviously wasn't?
Thanks. -
Read my original reply. You are in the UK ? When I had my tapes converted, the cost was £8 per tape. A very small price if these tapes mean anything to you. -
Originally Posted by DB83
The only reason i was saying about sending them back to the US was because i know lots of people worldwide who can transfer tapes to the standard i want, and would do it for free, so it would only cost me that postage again, which would probably be less than then £16 to get someone professional to do it. It's just finding someone who i know can transfer these Brazilian tapes. THey're not sentimental or anything, they're actually recordings of the 2001 Rock In Rio festival.
However if you could email me the details of that business so i can have a look at them, i'd appreciate it. simon.kilmore[at]googlemail.com
Thanks. -
Once you have a VCR that can play PAL-M, next you need a capture device. Best bet may be a simple NTSC TV tuner card that also supports PAL-M. Unless you have a PAL-M capable TV, monitoring will still be monochrome until the PAL is decoded into components.Recommends: Kiva.org - Loans that change lives.
While we wait for a Brazil dub expert to chime in, I can add some insight from the NTSC side of the pond. I have some background in the broadcast end of PAL-M and also have struggled with dubbing PAL-M source.
As a result, for a long time it was common in Brazil to have a homemade hack installed in most TV receivers, in order to make them work with NTSC (mostly american) VCRs, cameras, etc. Basically, this was just a switch to change the color subcarrier oscillator crystal from the NTSC to the PAL-M one. Nowadays, this "hack" is directly built into most equipment.
I hope to have added some insight from the PAL-M side of the story. Regards to all,
Elezer
[/i] -
Killer3737 - I would never assume that a US video house knows how to handle PAL-M or any kind of PAL. Maybe, maybe not. Here's a thread about a guy from Serbia who tried to get a place in Florida to copy an old PAL Beta tape and they ended up not knowing how to deal with it.
https://forum.videohelp.com/topic358606.html
This is to just to illustrate that just because someone in the US is in the conversion business that they may not know what they are doing.
Note that it requires special VCRs in the USA to deal with PAL-M. Such multistandard VCRs are difficult to find and can only be ordered from specialty shops. They are NOT available in standard electronics stores where the general public shops. -
Capturing PAL S-VHS-C - Advice very much appreciated
By Genu29 in forum Capturing and VCRReplies: 2Last Post: 31st Jan 2012, 07:02 -
Capturing unknow PAL VHS source. Can be watch on TV but not recorded on PC.
By Bellower in forum Capturing and VCRReplies: 13Last Post: 28th Dec 2011, 18:16 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 21:08 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 16:48 -
Capturing PAL VHS and DVDs to NTSC DVD
By joelkranz in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 16:11
