Hi, everyone! This problem is tricky for me.
I have this subtitle synchronized for a 25fps avi file and I have a new avi in 23.9 frames per second. And the problem is new avi is a bit different from the original one (there's a couple deleted scenes throughout the movie) so I can't use the usual method (sync points in SubtitleWorkshop). I mean if it wasn't for the fps difference I would've shifted the rest of the lines a couple times leaving gaps for deleted scenes, but now I'm really puzzled.
I've also tried loading fps from the avi file in Time Adjuster but it didn't worked either, even deleted a couple of lines instead..
What should I try now?
There is a option in subtitles workshop that changes subtitles framerate, did you tried it ? in the left side of the program window
oh geez, so easy..
Just tried it and it worked.
Thanks a lot!
How to convert from 60fps to 25fps to get continuous video?
By Bencuri in forum Video ConversionReplies: 236Last Post: 26th Aug 2012, 03:27 -
How Can I Convert 25FPS 720P To 23.976?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2011, 21:47 -
Convert FLV 25fps to 29.97fps
By Jason77 in forum Video ConversionReplies: 6Last Post: 17th Feb 2011, 16:34 -
canon 5d mkII 30fps to 25fps best way to convert?
By powertase in forum Video ConversionReplies: 3Last Post: 20th Sep 2009, 21:53 -
Convert a .dts file from 25fps to 23.976
By ranosb in forum AudioReplies: 9Last Post: 16th Jul 2009, 01:36
