I have 2 mini DVD disks and I want to put parts of each on to a standard DVD disk. Which way is best to do this for best quality?
I can just plug my camera in to my Panasonic DVD burner and use the PAUSE & STOP as I play the 2 mini dvd disks from my sony handy cam using a SVHS cable. Or will I get equal or better quality if I convert my mini DVD videos in to avi or mpg and then record them on the the stand DVD disk using a computer?
..or is there an even better way?
Thanks!
You can join and cut together the 2 dvd-video folders using for example tmpgenc dvd author or dvd shrink(no menus) without any conversion so no quality loss. See https://forum.videohelp.com/topic284279.html
Both of the mini-DVD's are made up of a few videos. Can I pick which of the videos from each of the 2 mini dvd's with both of those methods?
Can you copy multiple mini-DVD discs to one standard DVD?
By darkcyber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jan 2011, 10:44 -
mini DVD recorded by SONY DCR-DVD203 unreadable at DVD ROM of PC
By knightatarms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Dec 2010, 11:02 -
How do i put movies from camcorder mini DVD on DVD?
By seskanda in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2010, 05:33 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34 -
How to copy multiple mini DVD to a regular size DVD Please Help
By v36 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 12th Feb 2008, 18:48
