hi i'm using SVCD2DVD to convert several avi files. I'd like to split the movie into chapters for ease of reference - jumping to particular scenes. Can i do this using svcdd2dvd?
all help appreciated.
cheers
David
thanks gunlinger! I didn't explain myself very well, i don't actually want to split the video up, but in fact to put markers at particular points. how do i put these markers into a video file?
cheers
David -
It is generally done during the authoring stage, however very few all-in-one converters of anything other than either no chapters, x number of chapters, or chapters every x minutes. If you want to chose exactly where your chapters will go you will have to use a more manual authoring tool instead.
It may be possible to put chapter points in after the fact using tools like VOBBlanker and PGCEdit, but it will be a lot more work.Read my blog here.
Making a DVD with auto repeating chapters
By JJ72 in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2011, 10:59 -
Problem making chapters with RDR-HX780 Sony HDD recorder
By 1234567 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2010, 11:56 -
Making Movies is More difficult than I thought
By Alextaylor in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2008, 02:16 -
2 movies with seperate pagew for chapters of each movie possible?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 28th Aug 2007, 08:10 -
Nero 7 is making movies bigger than they should be...
By Harkonnen in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 02:59
